Hi everyone,
I'm a newbie here and I need some help to get this USB stick working on my vu+ solose box. The problem is that the solose box can't recognize this stick at all. I tried to install usbutils from feed and now it detects the device as ID 048d:9006 Integrated Technology Express, Inc. IT9135 BDA Afatech DVB-T HDTV Dongle . But after every restart it won't detect the stick! The only way to get detected this stick correctly is reconnect device on USB port??? It is shown in the attached dvb_debug files. Anyway detected or not, this tuner isn't working. I guess: there is a driver problem or something is missing. Any help will be appreciated,
cheers.
cheers.
 ... So, you must wait that someone, better than I, can answer your issues, for example
. I tried also blackhole 3.0.5L - same story. Only on VTimage my solose box recognized this stick as frontend usb tuner, although my goal is to get this stick working on blackhole.
!!! There should be a solution.....
