Hi, i've got a similar issue. I've got two vu boxes a vu+ duo and a vu+ solo2 in the same room
Ive managed to get the Universal Vu Solo+ Remote to work with my telly by changing the code to 2448
Ive also made sure the solo 2 remote is set on mode 2 which is meant to be the default as per the manual.
Mode 1 : SOLO / DUO
Mode 2 : UNO / Ultimo / SOLO2 / DUO2
Mode 3 & 4 : reserved for future models.
Press <<2 + 7>>, <HELP>, <0001 or 0002 or 0003 or 0004>
The issue I'm having is that when i use the remote its changing channels on both boxes.
Is it possible to have the solo 2 remote just control that box and the original duo remote control just control the duo.
Any help would be appreciated
