LCD picon on VU+ duo 2
Jim Copley
I make an error and installed LCD picon for ultimo on VU+DUO2. i don't have readen the note that the packet was only for ULTIMO and they were installed in /usr/enigma2/picon...
can anyone help me give me the command to remove them ?
Many thanks
Jim
Just install another picon set in the same folder, it will overwrite the previous wrong picons.
To simply remove the files use a FTP client.
To choose where to store LCD picons check LCD4linux settings.
i removed the file via ftp, after this i bought a 16 gb usb stick, plugged into the device, make 2 partion, 1 partition 4 gigs and the other 12 gigs.
The 4 gigs partition is mounted on media/usb the other partition is mounted on /universe so i can use it fot both the thing. storaging and parallel universe :D
