Missing dvb text on Animal Planet HD Canal-Digital and others!
twin
There will be a fix for all Dreamboxes running OE2.5, read about it here:
https://dreambox.de/board/index.php?thread/23942-dvb-subtitles-no-dvb-subtitle-on-animal-planet-hd-0-8w-canal-digital/&pageNo=1
Is this possible that the same fix is created for Vu + and Blackhole 3.0.5.?
The problem applies to all types of boxes.
OpenPLI 6.2 is the only image that has fixed the problem.
Nice if someone fixes this.
Are you using any blockers, on your browser, like Ghostery, or Adblocker?
The report requires you to fill out a simple Captcha, to test that you're not a bot.
Correct that i am using Ghostery and Adblocker.
But have also tried Firefox without these and does not work either.
Captcha is also correct.
Paste only items in from my post, tried with and without URL to dreambox.de.
Nothing works, Someone else can try.....
I can't report the problem for you, as I don't have the relevant information, or experience of the problem.
I can't even see any information regarding which VU+ model you have, unless you've posted it elsewhere, on the forum.
I have committed the changes to the BH image, so you should get it in the next update (whenever the image is ready).
I have Vu + Zero4K and Vu + Solo2
Runs Blackhole 3.0.5.L on both.
But the problem concerns all types of boxes and image.
As I'm writing openpli has delivered a fix to their image.
Fix comes to DB running OE2.5, OE2.0 will not be updated.
@Ev0
Very Nice:)
