Transmission
Tamaki
Here you can find the ipk files to install transmission 2.41 on your BH.
Remember to reboot your box after install.
Tnx to Angelofsky for the files.
After installing these files, how do I access the program?
What is the purpose / the usages of this plug-ins.....:confused:!
After install you have to reboot your box.
Trasmission should start automatically, to check it try a ps from telnet you should see something like:
/usr/bin/transmission-daemon -g /media/hdd/transmission
To access it use a browser and type:
http://IP_BPX:9091
You should enter in the webif and can manage your torrent program.
If i have time tomorrow i'll post the script to start and stop trasmission directly from box.
All the files insalled ok. I can also get the deamon to start.
But when i access the webinterface I just get this message:
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
I cant find any file to edit these settings
I can now fnd the setting files after running /usr/bin/transmission-daemon -g /media/hdd/transmission
But how do I start and stop the daemon? After a restart it does not seem to be running any more.
I prepared this pack with script i use to start and stop daemon and to enable webif.
Try to install and retry all.
Let me know if it works.
Web if user is root
password is pass
I can't install the .ipk files. Message: could not lock/usr/lib/opkg/lock: No space left on device.
Execution finished !! I have no memory space on my Vu???
Web if user is root
password is pass
I installed the script ok, but I get error when I try to run it:
/bin/sh: /usr/script/Start_Transmission_userscript.sh: Permission denied
I'm afraid the file lost linux format.
Try from telnet to give this command:
dos2unix /usr/script/Start_Transmission_userscript.sh
and then retry.
and then retry.
Thank you for your help, but I still have the same error.
If I run this command from telnet: /usr/bin/transmission-daemon -g /media/hdd/transmission
the program works perfectly, but I have to do this everytime i restart. So I realy need that script to be working, or get it to automaticly start when I start the box.
Try to see if in the file /etc/default/transmission you have:
DAEMON_ENABLED="YES"
