„Tune failed“ on Ultimo 4k with two DVB-S2 FSB Tuner
mahe1970
Hello,
I have an Ultimo 4K with two DVB-S2 FSB tuners. Since 2 weeks I use the image OpenBH 4.3.
My SAT system consists of a Quad LNB and a multiswitch. 2 cables go from the multiswitch to the receiver.
My tuner configuration looks like this:
  • Tuner A: Configuration Mode: Simple, Mode: Single, Satellite: "19.2 Ku-band Astra 1KR/1L/1M/1N"
  • Tuner B: Equal to "Tuner A"
  • Tuner C - Tuner H: FBC automatic
  • Tuner I: Configuration Mode: Simple, Mode: Single, Satellite: "19.2 Ku-band Astra 1KR/1L/1M/1N"
  • Tuner J: Equal to "Tuner I"
  • Tuner K - Tuner P: FBC automatic
I now have the following problem: if the box switches to tuner B or J, because tuner A and I are in use, I get the error message "Tune failed".
If I deactivate Tuner B and J, not all stations are available (Service unavailable). So I can start two recordings without problems, because tuner A and I is used.
Does anyone have an idea why I get the message "Tune failed" if Tuner B and J are enabled?
mahe1970
Two cables two physical tuners
other physical tuners can only be used as looptrough to (configuration Mode)
example A on cable, B looptrough to A
and/or Tuner I on cable, J looptrough to I
Hello Matrix10,
thanks for the tip. "Looptrough" worked. I tested it and was able to do more than 16 recordings at once.
I had set "Equal to" because I thought I had set it on the VTI image.
mahe1970
