2.0.7.1 install but plug in issues, help required please
spudorange
Hi
I am posting fresh away from lorenzo64's post " Black Hole Vu+ Solo v.2.0.7.1" as my issues probably are best posted separate.
Every plugin I add to the box Green button, Yellow Button, (manual install) gives the following error.
Error: Missing new line character at the end of file
It then reboots the image.
I have tried a number of them, 1channel, icefilms, live football etc etc
All return same error
Anyone have a clue please
Hi
Check files/packages you are trying to install into your box.
what does that mean check them, HOW do I check them?
I just put vix on and sent the same ones to it fine
So what am I doing wrong with the BH image
