Bouquets are just favourites folders, designed to make channel selection easier.
Adding a Bouquet, or ant nuber of Bouquets, should not affect your satellite reception, in any way.
To add a bouquet, bring up your list of channels, press the Blue button, on your remote, then the Menu button, and select the add bouquet option, and name it.
Add as many bouquets, as you want, then move the relative channels, into the bouquets, by bringing up the channel list, scrolling to a channel, pressing menu, and the add to bouquet option.
I don't believe bouquets, can be related to your problem, so please post back with more detailed information.
