Hi i have a vu duo2 i have 2 cams i want to use, when i insert one cam all the channels decode fine, when i insert both cams at the same time no channels decode at all, any fix for this? thanks
both are Irdeto 2 encryption, when one cams in it works fine but put both in and nothing loads get a PID error, did try the common interface assignment but still no luck
