2 OUTPUTS
blue
Hi guys can anybody tell me whether you can use 2 outputs on solo at the same time without causing any issues ( 1x hdmi...1x scart ) ?
I work with HDMI and Y, Pb, Pr same time.
hi i run a modulator from scart output to distribution unit for tv's around house and run hdmi locally on tv and the box locks up from time to time ? then have to hard reboot to resolve ? i,m currently using bh 1.7.3 and configured output on set up as hdmi 1080i !! maybe i try video rca's to feed modulator ?
Yes,,then you will have on TV 2 video out puts!
However, HDMI has better picture quality than 12 bin SCART!
May be in your case a normal A/V output would work!
I don´t run modulator, sorry I don´t know about it... on modulator you will work 560p as best resolution, I works on 1080i on both.
