256 flash memory,solo2
satdz
hi, are that the flash memory of 256MB SOLO2, does not affect the ability of the receiver to Téléchargment and storage,thanks
hello, yes I know the solo 2 has a memory of 256, but I wanted to understand if the memory is sufficient for transcoding, etc. HbbTV ... thank you
Hello.
Please check the file to all "messages" -
var / volatile / log / messages
Do you have it?
Mar  3 01:08:59 vusolo2 user.info kernel: EBI CS0: setting up NAND flash (primary)
Mar  3 01:08:59 vusolo2 user.info kernel: NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
Mar  3 01:08:59 vusolo2 user.info kernel: brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Mar  3 01:08:59 vusolo2 user.info kernel: Bad block table found at page 131008, version 0x01
Mar  3 01:08:59 vusolo2 user.info kernel: Bad block table found at page 130944, version 0x01
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000003200000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000005b40000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000008920000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000009360000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000009d60000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x00000a300000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x00000d1c0000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x00000eb40000
Mar  3 01:08:59 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x00000eee0000
Jan  1 06:00:25 vusolo2 user.info kernel: brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Jan  1 06:00:25 vusolo2 user.info kernel: Bad block table found at page 131008, version 0x01
Jan  1 06:00:25 vusolo2 user.info kernel: Bad block table found at page 130944, version 0x01
Jan  1 06:00:25 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000000a60000
Jan  1 06:00:25 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x000005b40000
Jan  1 06:00:25 vusolo2 user.info kernel: nand_read_bbt: bad block at 0x00000e9e0000
bad block - Is it normal for a new solo2?
