28.2E A few HD channels lost
keratos
I appear to have lost BBC ONE HD and CHANNEL 4 HD which are FTA I believe. In any event, they were working upto about 2 weeks ago
I've rescanned with "Clear channels=True" but this hasnt made a difference
Any ideas?
Any ideas?
I've lost these services too :( I don't say why :(
What does a network scan do in addition to a normal search with option "no" on network scan?
It will look for the network table that is broadcast on 1 of the channel transponders and then will scan frequencies that are not listed in the satellite.xml
DSAT 4
Astra 1N (28.2° East)
Transponder 50
Frequency: 10.84700 GHz
Vertical polarisation
Modulation: DVB-S2, QPSK
Symbol rate: 23.0 Mbaud
FEC 8/9
Transport Stream ID: 2050
After the 27th September 2012
Transponder 50
Modulation: DVB-S2, 8PSK
FEC 2/3
Channel SID
BBC HD 6940
BBC One HD 6941
I hope you can read the above, I had a similar issue and re-scanned (MANUAL SCAN) with the above information. The FEC has changed to 2/3 from 8/9 and the QSPK should be changed to 8PSK. This is apparently to make way for regional HD channels in the future. Alternatively update your channel list to one after the 27th September and that should work too.
Hope this helps.
