2nd Infobar missing
josephine5899
Hi,
Please can someone help. I've installed BH, but there is not a 2nd infobar.
Also, in expert mode, there is no 2nd infobar setting (ie 10 seconds). Is it possible, as the info in there is very useful when used on other images.
Using vu+ duo2.
Thank you,
Hi,
Using vu+ duo2.
Thank you,
Can you point us the image version you are using your STB?
Note: This is not a newbie question, you must ask for support regarding the image and STB model you use.
So, next time, ask for support in the correct section.
