As told in the object, the plugin SerienFilm whose author is reported to be AWD, does not install in 3.0.1. It's a pity because it is so useful!
This plugin is not to be mistaken with the addons with similar names.
I must correct my previous message: the plugin do install but it has got huge problems: as soon as I try to enter the recording list the box get stuck and , after a while, I get the GSD.
The exact plugin name is SerienFilm 1.1
Again , MovieSelection coding is not compatible with coding we use inside our image skin coding.
example , We can not modify our coding and have a very small fonts in MovieSelection to be able to use this plugin.
The problem is that images coders and plugins coders do not use the same line for coding
but everyone does sometimes something different with modifications.
Sometimes it is possible to compensate
but in this case not because the plug-in uses the same coding from default skin coding
but plugin coding is different from the image coding.Then we have a conflict.
