3.0.5I VU+ Duo2 HDMI sync with TV does not work
tmykrk
Hi
I lost the HDMI synchronization with my TV. In version 3.0.3 it worked correctly: I turned on the VU+ and switched on the TV immediately with VU+ remote. Likewise with switching off.
Now, with 3.0.5I TV does not see VU+ Duo2 on the list of synchronization devices. PS3 is seen correctly.
Regards.
:-) No, I did not even know that it exists. I do not know how it was done in version 3.0.3.
Thank you very much. I will search, install and check.
Regards.
If I remember well, because I no longer use BH but almost only OBH, you don't need to install anything: it should be in the submenu system or within the already available plugins (GREEN/YELLOW).
:-) Got it! I understand! I found! Works perfectly with default settings. Thank you very much. Apparently I set it up so long ago that I forgot about the existence of this plugin.
Regards
