I'm sure I've seen a plugin you can choose when watching 3D side by side material so that the on screen display goes into both half images and becomes perfectly watchable. Seems it's no longer in the BH feed. Anyone ???
Right. Sorry to insist but I've managed to find the plugin on the BH feed. It's called 3D OSD Switcher but it doesn't install. Anyone could walk me trough this please ??
Thanks but not the one I'm looking for. The one present on the speedup menu is the UI3D setup plugin which is useless anyway. You should use your 3D TV menu for that.
