4 Tuners
rob waterston
Hi
I have loaded open blackhole 0.4 on my Vu+ Duo2
I have set the fist tuner A to Advanced this is on a motorized dish
the other 3 B C D all to single on a static dish at 28.2
I can only record a single channel and the rest are blank so changed all to single on 28.2 can record and watch A and C B and D are blank any help as to how to configure the tuners please.
I assume you watch 28.2 more than you use the motor ?
If so, then I would set A, B, C all as simple and then tuners, 28.2, then you should have no problems as each tuner will use the feed from 28.2 independent of eachother.
Then use D as your motor (if your using a diseqc motor then set it to simple, motor and use usals), if it's an older 36v with v-box then advanced is the way to do it.
Hi Evo
I have set this up as listed ,and it finds the sat 28.2 on search via auto function and locks to it tuners A to C the last one D set as stated but when recording via tuner A B gives a blank screen this is a new blackhole 0.4 thinking it may be a bug. it is like itdoes not see the second half of each tuner ie B and D
