5W transponders missing in OBH
scorpion007
Hi guys, since 4.3 027 I have noticed some transponder not working on 5W mainly Italian ones like la7 they use to be fine with previous versions, I switched to BH and they work as normal on that image. canale 5 rete4 and italia 1 only worked on SD then I reinstalled to settings and they came back except for la7. Can anyone confirm if the image has a problem. The other thing is when you do a new scan it doesn't have the MIS transponders in memory so it swipes all these transponders.
I haven't got a multistream capable receiver, so I can't offer too much help, but I can see, on lyngsat, that the channels are listed on two separate transponders, which might mean that they are changing transponders, or have already moved.
Which transponders are you checking?
La 7 channels are listed on 12522 V and 12606 V:
https://www.lyngsat.com/Eutelsat-5-West-A-B.html
