******* 6.4 and BH 1.7.7 light
regenold
******* won't install having ftped it to the tmp directory and choosing manual addon install via remote but the following method works.
Summary:
Download latest *******
Unzip and rename ipk file to something simple eg; tsp64.ipk
Ftp to /tmp folder of your duo
Telnet to your duo and change the permissions of the package file eg;
chmod 755 /tmp/tsp64.ipk (change the filename to whatever you renamed it to, if different)
Then install using the command below (change the filename to whatever you renamed it to, if different)
opkg install --force-overwrite /tmp/tsp64.ipk
After installation, restart your duo and all should work.
More info:
Ftp and telnet clients to complete the above steps are built into VU+ Control Centre .
To find your box's local ip: Using the remote press menu -> setup -> system -> network
Then select the interface that you're currently using and finally adapter settings to display the ip
Default BH Image logon details are user: "root" and password field is blank.
i have one 100% ok
install ******* 6.0 ( put your ipk in the /tmp , after that green button and yellow button and install manual ipk)
reboot your gui
now enter in your panel in the plugin menu and update your plugins 6.4 .
end
If I remember correctly we're here already mentioned a couple of times that we do not provide support for TS panel .
Since I did not want to play the parrot
next time follows a ban from the forum.
No support for illegal contents on this forum.
Read the forum rules.
