A867 Terrestrial USB stick
Wendy
On my Vuplus Solo2 with BH Image, my A867 Terrestrial USB stick is immediately activated upon the Image installation as the drivers are pre-loaded into the Image itself and everything works flawlessly.
Today I decided to install the OBH Image and noticed that it does not come with the pre-loaded drivers.
So I downloaded and installed them (AF9035) and rebooted.
But after a couple of Channel changes from Sat to Terrestrial, the Image hangs (showing the spinner endlessly) until I restart the Box.
I reflashed the Image and repeated the whole process but got the same annoying result.
Any help please?
Many thanks.
It seems that this also happens on other OE-Alliance Images.
Can anybody indicate how I can relay this problem to them please?
