younes-o2 Vu+ User Jan 8, 2014 #1 DD subtitle player crashes with green screen.(bhole 2.0.8.1 vusolo).Have you the same problem?Thank you.
paolino Vu+ User+++ Jan 9, 2014 #3 younes-o2 said: 27 views .NO RESPONSE!!!! yes or no is sufficient. Click to expand... Where is a crashlog? Without it nobody can help you.
billis2 Vu+ Newbie Jan 9, 2014 #4 some problems for this plugin is utf8 subs make ansi and work stabile
