ACC-HE audio in VU box ?
segredo
hello
like to ask whether any bh image is prepared for the ACC-HE audio.
MEO provider in 30° W to change the sound for this encoding.
in the VU + DUO box has written it decodes it this kind of audio.
I have some colleagues with AZbox and not have this problem!
thank
segredo
Hello segredo.
ACC-HE audio works ok in VU+DUO if you don't go to a channel with ACC audio, anyway, if you go to a ACC audio channel, reboot your box (not only a enigna2 reboot, you have to do a complete reboot) and then the ACC-HE audio channels will be ok again. Note that o have to reboot in a no ACC audio channel.
Anyway, this is just a way to circumvent this issue.
Would be very good that this issue (ACC-HE and ACC audio channels simultaneously) could be solved.
Same here
it will be very nice if the problem is solved....actually only work good with a recent emulator but if the image can fix this it will be very nice
regards
Hello segredo.
is it working too on SOLO with BH 1.6.4?
this issue is reported in several places and isn't only a Vu+ problem...
it occours in all E2 receivers including AZBox with E2 installed (i have one). The only way i know to solve this, for now, is using last Ccam or ***** to read the meo card and you will have sound... tested in Vu+ with BH1.4.6 and in AZ with Spaze Fix
It's a warning: don't talik about emus in this Board: it's FORBIDDEN.
