Accessing recorded program make remote inactive
zhlad
Hi all,
Today, I flashed my Solo2 with BH 2.1.7, earlier I had latest Open BH image. When I was installing MovieSeries plugin, I updated all the pulgins, as suggested by Image. When I access recorded programs, my remote becomes inactive, I have to switch off and on from the back of the box to get remote working.
All buttons work fine, its just when I press recording button it becomes inactive.
What should I try to fix it?
Thanks.
Sent from my GT-I9505 using Tapatalk
Hi all,
Thanks.
You must have probably a crashlog. In order to help you, post it here.
You can found it on your /media/hdd folder or in your /home/root .
I have two crash logs in /media/hdd
enigma2_crash_1380226382
enigma2_crash_1380304736
Both are attached.
Timestamp indicates they are old logs?
/home/root is empty.
Thanks.
One of the logs are dated from 26 Sept 2013 and other from 27 Sept 2013, both regarding BH 2.05, not supported yet ...
1) - Check remote batteries
2) - Maybe your HDD must be too initialized ...
3) - By the way, have you replaced your TV SET for a new one? This could be another that causes malfunctions the remote control.
As you don´t have any crashlog´s regarding the image you have installed now ( BH 2.1.7 ), can´t help much more.
