Solo2 Acting funny, but not really funny
suveren
Hello
My box started acting out yesterday, so I had to re-flash it.
I had problems installing the correct *******, so i forgot to take out the usb-stick from the front panel.
There was flash files for BH 205 on it, so it has flashed itself numerous times without me knowing.
Wasn't it supposed to wait for a keypress?
After installing, the remote control no longer works. I have to use the webinterface to control it.
When done installing, it start to flash the shutdown meny by itself.
Also the led on the left side on the box is flashing unevenly, can't remember seeing that before?
Sometimes it wont start at all, just hangs on the Starting...
Other times it will go to setup menu after flashing again.
Is the box toast, or what? Why is it flashing without asking for confirmation?
Installed an earlier version of BH, 204. The most common error is very long startup times, and automatic shutdown menu toggle without interacting with remote control or anything else. It lives it's own life..
It is not responding the remote control, and it takes at least 90 seconds to start, if it starts at all.
The remote control is not working as it should. It seems the box sees something, but none of the buttons does what they are supposed to. Via the webinterface I tried to reassign the remote control code, but no help in that. And I have changed the batteries.
Hello
We don't support in any kind of form plugins like the one you are try to install because contains illegal materials not admitted here.
Thread closed. Next time: ban.
