Activate OpenVpn First
daviduzzo
Hi guys,
I hope you could gently help me.
I tried NordVpn connector without success on BlackHole 3.0.9.E.
So I create, Client.conf and login.txt, put them into /openvpn folder, to be sure I put also ****.nordvpn_com_ca.crt.
Then I go to Additional Configurations. Kernel Modules, Tuner Module for Openvpn--> YES (it's like sometimes it's active, trough yellow--> see active module and sometimes it's not)
So i go into Openvpn I do green-- start, but everytime I get "Activate openvpn first"
What can I do? Where is the problem? Am I wrong?
Thank you guys
Now I can start openvpn service but just for few seconds, I tried with both udp and tcp connection nordvpn. Some tips?
I think that problem is that kernel module that I actived appears and disappears from the list of active modules
