Adding DVB T stick to DUO2
RatManJoe
Hi guys
Some help please
Currently have DUO2 with 1 x double DVB/S2 and 1 x DVB C/T tuner
I want to replace DVB c/t tuner with another double DVB/S2 tuner
Giving me 4 x sat tuners
(On my Solo2 I have a DVB/T stick in usb to give me terrestrial channels + 2 x sat channels)
If I add same DVB/T stick to DUO2 usb can I get 4 x sat channels and 1 x terrestrial channel
for example record 4 satellite programs and watch 1 terrestrial
Is this possible???
Yes, sure.:)
Your DVB-T USB tuner should be correctly recognized also by the Duo2 if currently used on the Solo2 with BH 2.1.4.
One more question on this subject.
Now have installed 2 x dual DVB/S2 tuners installed + DVB/T usb stick. (in theory 5 x tuners)
Duo2 only seeing 3 x sat tuners + the DVB/T ie 4 tuners in all (leaving me with 1 obsolete sat tuner)
Is 4 tuners the max the duo2 can cope with or is there a solution
On the tuner back panel, printings near the 2 F-type connectors are as follows:
IN - IN -> dual
IN - OUT -> single
