Advanced Movie Selection Crash (Default Paths)
Sherlock
Hello,
I have a VU+ Uno with BH 1.78 installed.
I'm using Advanced Movie Selection plug in, but in setup when press the blue button to change "default Paths" allways crashes and gives me a geeen screen and reboot!
Any solution for this?
Thanks,
Sherlock
Hello,
Thanks,
Sherlock
Yes U are correct!
However, U can use >>Menu>>setup>>system>>Recordings Paths!
