Hi All;
i need a help, i have monoblock LNB and 8X1 diseqc switch with OPENPLi i can connect Monoblock to Diseqc directly (without a spilliter) and select two satellites for monoblock
This means i can connect two satellites from monoblock to diseqc without wasting ports
But in Blackhole i do not have that feature..
Can anyone help me with this...
Hi tks.. but what i'm loooking for setting like this..
where you see there is option for both Diseqc switch 1.0 and 1.1
With this you can directly connect monoblock to Diseqc 8X1 (1.1) without a spilliter
Configuration Mode: Advanced
Satelitte: Your Choice of sat position
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Voltage Mode: Polarization
Increased Voltage: No
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Committed DiseqC Command: AA
Fast DiseqC: Yes
Sequence Repeat: Yes
Command Order: Committed,Uncommitted,Toneburst
Uncommitted DiseqC Command: Input1
DiseqC Repeats: One
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Fast DiseqC: Yes
DiseqC Repeats: One
