Advantages of Blackhole
dixons
I'm new to VU, so bear with me.
Why would I want to change the image that came with my VU STB to the Blackhole image. What are the advantages and disadvantages.
Regards Geoff
Regards Geoff
I think the question is not advantages, but i think you should try some images and use the one the can adapt in the better way to you needs.
I think only after try some you can choose the one you like most.
There are many thinks the characterize an img: speed, stability, graphic, addon server, forum support ...
The beauty of this hobby is that you can try :)
Regards Geoff
I will summarize the advantages in one statement
Black Hole is stable and user friendly
And The Skins choices are ًFantastic
Use It Once, And defiantly you will never change
:inlove:
Warning
Falling in love with Black Hole image will happen from the 1st use
And its addictive
:inlove:
:welcome: to BH Fun Club
