Advice please on Vu Duo ver 1
mase2hot
Hi All
Need some advice please I'm currently on blackhole 2.1.7 with a Vu Duo version 1. I seen you can get BBC iplayer although the version I downloaded doesn't show any shows just help and about in the menu.
Looking on here I see XBMC being talked about and kodi so not sure on what the best setup I should be doing / supports my box, as I'm not sure if some of this stuff is Vu Duo 2 only.
Can someone advise on which image I should use and what plugins I can use to get the best out of box?
Ideally I would like, BBC iplayer, ITV Player, Netflix, Amazon instant, Plex etc.
Thanks
Yes it is genuine, thanks.
I have installed 3.0.2 but when trying to install ***** I get the below, any ideas?
"Not selecting enigma2-plugin-cams-*****.2.3.0 1.0 due to incompatible architecture."
