Aidio keeps changing to NAR on channel change
markmr3
I got up the other morning and my stb had switched its self off, Strange I thought. But now I have noticed that Whenever I change channel it puts itself on the NAR audio setting. How do I stop this happening. I have set it to normal audio then done a Enigma2 restart but it doesnt help. Thanks
By "set it to normal audio", do you mean you have gone into the Menu, Setup, System, Auto Language Selection Settings, and set your preferences?
Sorry for the late reply, ive been away. Ive gone into those settings and everything seems to be ok with them. All the subtitles are turned off and the main audio 1 is on English. I cant find anything related to NAR.
NAR is the narrative audio stream, for the blind, it's usually on by default, unless you change, and save, the settings in the audio options.
Once you select your audio preferences it should disappear,
Set option 1 to English, option 2 to undetermined, and option 3 to original, save them, and it shouldn't appear again.
