Airplay plugin
dreamingb
Hi
I am using Airplay plugin latest version on Vu+ Duo with fimware 1.7.2. But there is no sound when i play video from youtube from iphone. its working fine with apple tv. That has been working before under firmware 1.7.1
Mito
Hi
Same problem here...
I am using BH 1.7.0, Air Player 1.10
With BH 1.7.2 and Air Player 1.10 there is no audio problem.
I verified it with iPhone 4 and 4S.
XabiX
I have installed the 1.10 proposed through the BH Add On manager but if I press update then it uninstalls this version and installs a new one but I don't have any plugin afterwards.
Are you still using the 1.10 or there is newer version?
I have the audio issue but have to investigate a little bit more
perise
I had the same problem, so I directly download the last version from Google Project Hosting. The installation went fine BUT there is a surprise: audio files work but just for some days because you need a so called "premium key" if you want this issue forever.....so you should pay for it!!! I decided to go back to 1.10 that (for me) works better with video files. For audio files I use Airflick on my Mac and everything is ok!
Dani
Exact same problem with Ultimo and BH 1.7.6 too.
Since installing Airplay on my Vu+ Ultimo, i noticed the option has come up on all my idevices.. cool.
I selected the option on my Iphone 3GS and it scrolled a window the listed "IPHONE" or "Air Player E2"
When i select "Air Player E2" whilst something is playing on my iphone, the audio stops and i presume its meant to be sent/received ont he Vu+
Yet nothing...
I have then gone into Plug-Ins and started Air Player.
Only once did a media playing type window open, then closed straight away....
Am i using it wrong?
Is it meant for stream from the Vu+ TOO idevices or to stream from Idevices too the Vu+
Or both??
Thank You :)
Dani
Airplay works brilliantly now.... its amazing.
Whatever is playing on my Macbook or Iphone is now played on the Vu+ with push of a button!!!
Whether that is a local movie or YouTube or whatever.
How ever, i can not get AirPlay to stream any type of Audio file???
Is this the "Key" issue?
rominet
hello
how u make it works on bh with iphone pleeeeeeeeeeeeeeeeeeaaaase:cry:
