aiuto per usb dvbt my gica
Ciao angelo ho trovato in giro queste informazioni sul mio device credi che possono essere utili? Ora te le posto
Bus 002 Device 006: ID 0572:c688 Geniatech T230 DVB-T2 TV Stick
usb 2-4: new high-speed USB device number 4 using ehci-pci
usb 2-4: New USB device found, idVendor=0572, idProduct=c688
usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-4: Product: USB Stick
usb 2-4: Manufacturer: Max
usb 2-4: SerialNumber: 080116
dvb-usb: found a 'Mygica T230 DVB-T/T2/C' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Mygica T230 DVB-T/T2/C)
i2c i2c-5: Added multiplexed i2c bus 6
si2168 5-0064: Silicon Labs Si2168 successfully attached
si2157 6-0060: Silicon Labs Si2147/2148/2157/Si2158 successfully attached
usb 2-4: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-4/input/input24
dvb-usb: schedule remote query interval to 100 msecs.
dvb-usb: Mygica T230 DVB-T/T2/C successfully initialized and connected.
si2168 5-0064: found a 'Silicon Labs Si2168' in cold state
si2168 5-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
si2168 5-0064: found a 'Silicon Labs Si2168' in warm state
si2157 6-0060: found a 'Silicon Labs Si2146/2147/2148/2157/2158' in cold state
si2157 6-0060: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
NOTE: This device needs I2C-Mux support in kernel or as kernel module (CONFIG_I2C_MUX).
Firmware for both the demodulator and tuner are necessary. OpenELEC dvb-firmware collection includes firmwares for this device too.
  • dvb-demod-si2168-b40-01.fw
  • dvb-tuner-si2158-a20-01.fw
Place the 2 firmware files in /lib/firmware.
md5sum:
d8da7ff67cd56cd8aa4e101aea45e052 dvb-demod-si2168-b40-01.fw
Sono utili ... con la BH 2.1.4 tutti i moduli necessari sono presenti, ma senza un dmesg dal tuo box con il device collegato è impossibile sapere se e dove si "rompe" il riconoscimento.
Puoi provare anche a fare così (valida alternativa):
1. avvia il box senza device DVB USB collegato
2. una volta partito, con tutta calma ti prepari Putty con il comando per estrapolare il dmesg (vedi mio post n. 9 in questa discussione)
3. colleghi il dispositivo alla porta USB
4. esegui il comando
5. posti il risultato
Questo dovrebbe essere sufficiente per vedere come stanno le cose e cosa gli manca.
ciao angelo ti posto il file dmesg che mi hai chiesto di fare in più anche il messaggio lsusb come segue,con pennetta inserita dopo riaccensione del decoder , fammi sapere se va bene grazie.
root@vuuno:~# lsusb
Bus 001 Device 002: ID 0572:c688
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0001
Bus 004 Device 001: ID 1d6b:0001
root@vuuno:~# lsusb
Ok ora si ragiona.
Il driver per il tuo device non è presente, ma esiste.
Vedremo che cosa si può fare con la prossima BH visto che stiamo lavorando ai driver aggiornati per tutto lo stack DVB.
Ciao angelo allora dici che devo aspettare si sa quanto,scusa la mia fretta ma ho comprato questa pennetta per sostituire quella che avevo che si è rotta , non hai per caso una procedura con la quale io possa inserire intanto solo i driver per la mia pennetta, te ne sarei molto grato
Il tempo è ignoto. Ho sentito il collega che sta preparando la base per i driver aggiornati e ci sta lavorando da qualche giorno e si spera che siano pronti per la nuova BH.
Per quanto rigaurda aggiungerli a quelli attuali, devo vedere se li ho da qualche parte o, alla peggio, riprepararli.
