yoramile1 Vu+ User Jan 21, 2017 #1 all skins in 4k not work "heb" no epg no osd Please support in hebrow
Matrix10 Administrator Jan 21, 2017 #3 yoramile1 said: Hebrew Click to expand... Is it a question of the skin or image coding ?? If skin ,you have to find a font that supports Hebrew . Which skin support Hebrew Does the original VU + Skin support ??
yoramile1 Vu+ User Jan 21, 2017 #4 My question is about coding skin In my ultimo 4k imge 3.0.3 not support I dont see hebrew in epg The older skins 3.0.2 in my uno hd was supposed Last edited: Jan 21, 2017
Matrix10 Administrator Jan 21, 2017 #5 Give me some channels for testing in West EU from 40E to 1W on 13E or 19E ???
Matrix10 Administrator Jan 21, 2017 #7 I do not think I can look in the northwest of Europe with 80 cm dish.
yoramile1 Vu+ User Jan 21, 2017 #8 I succedded I changed it of that in the skin.xml <font filename="nmsbd.ttf" name="Regular" scale="100"/> now I can see hebrew
Matrix10 Administrator Jan 21, 2017 #9 yoramile1 said: I succedded I changed it of that in the skin.xml <font filename="nmsbd.ttf" name="Regular" scale="100"/> now I can see hebrew Click to expand... This is the way. You can try also this font , not sure if you have Hebrew. Attachments LiberationSans-Regular.zip LiberationSans-Regular.zip 84.5 KB · Views: 2
