Android with IR port as remote control
serdeliuk
Hello,
Working to port a Sinclair Spectrum emulator on my Vu+ Solo4K i saw that the kernel allow more commands over IR then my RC has.
The original universal RC has 43 working keys while the kernel module allow 91 keys to be sent over the IR
Ok, so how to find the keys codes to be sent over IR? This is how the irBuster has been born.
I have builded an android app which can send virtually any codes over IR, actual version works only with RC6 mode 6 version 6A 32bit but can be easy modified to send any code over any kind of frequencies or standards.
Anyone interested can find the source code and the apk installer on my github repo https://github.com/serdeliuk/irBuster
Does anyone have a qwerty IR remote control? Or a hex code from one of the buttons?
Enjoy
M
P.S.
Here is a screenshot
[/QUOTE]
I am asking for a qwerty code or if anyone else have a qwerty ir remote control to gain a such code, my next project is to build an android VU remote control with qwerty buttons, actually all kernel supported buttons.
