Animation
jrbmw
I cant find how to turn the animation off to stop the info bar flying off the screen or the menu from pulsating....using latest update to obh 0.6
Thanks for that , I will give it a try ....Seems back to front , I would have thought there would be no animation in the image then use the plug in if you want it animated
I agree. I was so sure it was like you said, I was becoming crazy looking for this setting even because I was sure it was built in the image as a standard menu and I remembered I had tried each setting in the past.
After having wasted a lot of times, I found out I now need a plugin.
But what is important is underline to OBH developers how annoying is this behaviour. If it was just a mistake in the update, OK... otherwise I think (but not only me, it seems) that NO animation should be the standard set up of whatever image.
