Another stuck at 'Starting...' problem!
lordbyte
Hi Guys,
I recently bought a VU+ Duo receiver, which came with Black Hole 1.7.0.
I tried to update to the latest 1.7.9, but after rebooting, the receiver got stuck at 'Starting...'
Searched this forum and saw others have had the same problems - So I did what it was recommended before;
Flashed original 7.0 image - It boots OK
Flashed updated bootloader - OK
Flashed 1.7.9 - Stuck
Flashed 1.7.6 - Stuck
Flashed 1.7.5 - Boots OK
Flashed bootloader again, rebooted - OK
Flashed 1.7.9 - Stuck at starting...
Any idea what is going on - Why would it boot images up to 1.7.5 normally and from there on get stuck???
Thanks
OK, I have made some progress here - Dumped the whole process of updating CFE, Re-flashing 1.7.9 and booting it and getting the following - Basically kernel crashes but I have no idea why -
BCM73350010
012
BCM73350010
012
Shmoo Version=1.9
MEMC-00000000 RW=00000011 WW=00000047 G=00000001 R=00000008 W=00000019
MEMC-00000001 RW=00000010 WW=0000004D G=00000001 R=00000009 W=00000006 #$
3
COPY CODE
A567
BCM97335B0 CFE v2.17, CFE core v2.12, Endian Mode: Little
Build Date: Thu Sep 29 12:01:32    2011 (shcheong@ncsh)
Copyright (C) Broadcom Corporation.
writing vfd
DDR Freq:      395MHz
CPU speed:    405MHz
Memory Config: 32+16 non-UMA
Device Tech:  1Gb
Total memory:  384MB
Boot Device:  NAND
ECC:          Hamming
Total flash:  128MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
USB: New device connected to bus 1 hub 1 port 1
USB: Resetting device on bus 1 port 1
USB: Locating Class 08 Vendor 18A5 Product 0302: Mass-Storage Device
USBMASS: Unit 0 connected
checking usb
Reading usbdisk0:/vuplus/duo/cfe_cfe_auto.bin:  >> Done. 287604 bytes read
Programming...
done. 287604 bytes written0 0x20000 done
please remove usb first and reboot
USB: Device disconnected from bus 1 hub 1 port 1
USBMASS: USB unit 0 disconnected
BCM73350010
012
BCM73350010
012
Shmoo Version=1.9
MEMC-00000000 RW=00000010 WW=00000047 G=00000001 R=00000008 W=00000019
MEMC-00000001 RW=00000010 WW=0000004C G=00000001 R=00000009 W=00000006 #$
3
COPY CODE
A567
writing vfd
DDR Freq:      395MHz
CPU speed:    405MHz
Device Tech:  1Gb
Total memory:  384MB
Boot Device:  NAND
ECC:          Hamming
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Reading usbdisk0:/vuplus/duo/cfe_cfe_auto.bin:  >> Skipping...: File not found
Reading usbdisk0:/vuplus/duo/root_cfe_auto.jffs2:  >>
Reading usbdisk0:/vuplus/duo/root_cfe_auto.jffs2:  >> Done. 77070336 bytes read
nand_erase_block 0x1af60000 0x20000 done
nand_erase_block skipping: at blk addr = 0x1af60000
nand_erase_block 0x1e9c0000 0x20000 done
nand_erase_block skipping: at blk addr = 0x1e9c0000
Programming...
done. 77070336 bytes written0x20000 done
Reading usbdisk0:/vuplus/duo/boot_cfe_auto.jffs2:  >> Done. 576 bytes read
Programming...
done. 576 bytes written0000 0x20000 done
Reading usbdisk0:/vuplus/duo/kernel_cfe_auto.bin:  >> Done. 3543842 bytes read
Programming...
done. 3543842 bytes written 0x20000 done
BCM73350010
012
BCM73350010
012
Shmoo Version=1.9
MEMC-00000000 RW=00000010 WW=00000045 G=00000001 R=00000008 W=00000018
MEMC-00000001 RW=0000000F WW=0000004A G=00000001 R=00000008 W=00000007 #$
3
COPY CODE
A567
writing vfd
DDR Freq:      395MHz
CPU speed:    405MHz
Device Tech:  1Gb
Total memory:  384MB
Boot Device:  NAND
ECC:          Hamming
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/de
v/mtdblock0 rw mem=0x8000000 bcmrac=3
Loading: 0x80001000/6951200 0x806a2120/122064 Entry address is 0x8053c720
TP1 Entry Address at 0x80000ffc = 8053c720
Starting program at 0x8053c720
Linux version 3.1.1 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1
SMP Mon Dec 3 19:03:01 CET 2012
Fetching vars from bootloader... found 11 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 256 MB + 128 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
bmem: adding 112 MB RESERVED region at 144 MB (0x07000000@0x09000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  Normal  0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00010000
PERCPU: Embedded 7 pages/cpu @81203000 s4384 r8192 d16096 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw ro
otflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 138220k/262144k available (5407k kernel code, 123924k reserved, 1139k da
ta, 244k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Detected MIPS clock frequency: 404 MHz (202.498 MHz counter)
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 5: set to [mem 0x10510000-0x10510fff] (PCI address [0x1051
0000-0x10510fff])
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Registering unionfs 2.5.11 (for 3.1.10)
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 269
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
brcm-pm: enabling sata clocks
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:be:07:a0)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
ata1: SATA link down (SStatus 4 SControl 300)
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d,
tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007600000 : "rootfs"
0x000007600000-0x000007a00000 : "kernel"
0x000007a00000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
ata2: SATA link down (SStatus 4 SControl 300)
UBI: max. sequence number:      0
UBI: volume 0 ("rootfs") re-sized from 586 to 929 LEBs
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            118 MiB
UBI: number of good PEBs:        942
UBI: number of bad PEBs:        2
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 942
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1/0
UBI: image sequence number:  1210849233
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 45
UBIFS: start fixing up free space
UBIFS: free space fixup complete
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  116563968 bytes (113832 KiB, 111 MiB, 918 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 244k freed
mount: mounting sysfs on /sys failed: Device or resource busy
procmk_init
dvb_bcm7335: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (bm750)
bcm7335: hotplug_callback():
Hotplug - status.connected 0
CPU 0 Unable to handle kernel paging request at virtual address c072b790, epc ==
c072b790, ra == 80078154
Oops[#1]:
Cpu 0
$ 0  : 00000000 10008700 c072b790 00060000
$ 4  : 0000000d c0b229e4 00020000 00000001
$ 8  : 10008700 1000001f 0000029b 77059a58
$12  : 000000e6 00000e60 000000e6 00401048
$16  : 8761f300 00010000 00000000 00000000
$20  : 00000001 0000000d 00000002 8063cd80
$24  : 0006ce50 77035058
$28  : 88f3a000 88f3bcb0 00010000 80078154
Hi    : 000001c0
Lo    : 00029cdf
epc  : c072b790 0xc072b790
    Tainted: P
ra    : 80078154 handle_irq_event_percpu+0x5c/0x2f4
Status: 10008302    KERNEL EXL
Cause : 00800008
BadVA : c072b790
PrId  : 0002a044 (Brcm4380)
Modules linked in: procmk
Process rcS (pid: 67, threadinfo=88f3a000, task=88d46da0, tls=77062490)
Stack : 88f3bd00 8120c020 8120c028 8007093c 80664b60 00000000 8063cd80 00010000
        00000001 00000020 00001400 fffffbff fffff7ff 77035058 77058f00 8007843c
        00000000 80640bcc 80640bcc 80070fac 00100100 00200200 8063cd80 8007bf24
        00000000 8849e128 0049ecd4 81026160 81025d20 00000000 0000000d 80077b98
        00974b5b 8000e26c 76fe4000 88811380 00000000 800069d8 884d8180 8008482c
Call Trace:
[<8007093c>] generic_exec_single+0xf4/0xfc
[<8007843c>] handle_irq_event+0x50/0x84
[<80070fac>] smp_call_function_many+0x134/0x3c0
[<8007bf24>] handle_level_irq+0xd8/0x16c
[<80077b98>] generic_handle_irq+0x34/0x54
[<8000e26c>] flush_tlb_page+0xe4/0x190
[<800069d8>] do_IRQ+0x18/0x24
[<8008482c>] filemap_fault+0xd0/0x5b8
[<80011730>] copy_user_highpage+0xcc/0x104
[<800b1e1c>] page_add_new_anon_rmap+0xa0/0x134
[<80002700>] brcm_intc_dispatch+0x90/0x220
[<80011748>] copy_user_highpage+0xe4/0x104
[<80002964>] plat_irq_dispatch+0xd4/0x110
[<800a5708>] __do_fault+0x504/0x708
[<80004ee4>] ret_from_irq+0x0/0x4
[<80010d74>] do_page_fault+0xe4/0x330
[<800abb20>] find_vma+0x3c/0x9c
[<800bfc04>] filp_close+0x78/0xac
[<800bfcf8>] sys_close+0xc0/0x11c
[<80004ec0>] ret_from_exception+0x0/0x24
Code: (Bad address in epc)
---[ end trace 8a0f8c6c51c9fb1f ]---
Kernel panic - not syncing: Fatal exception in interrupt
Rebooting in 180 seconds..
Any ideas what's going wrong please??
Thanks
Did you upgrade the bootloader? If not you should find it somewhere in the forums then you can upgrade to 1.7.3 or higher.
May be U have corrupted image!
Download a new image and extract to USB (after U do erase format)
Thanks Guys,
The first two sections of the log are
1) The updating of the bootloader
2) Flashing of the 1.7.9 version
To me both of them are flashed correctly (i.e. the log does not show any errors) - It must be the 14th time I have downloaded an image (from version 1.7.6 to 1.7.9) and flashed it - they all crash apart from images less than and including version 1.7.5 - I am guessing these use an older kernel -
Now why the older kernel does not crash on boot like the new one, I cannot explain and was hoping the experts here could give me some insight.
How can I make sure that this is true? It has been sold to me as the genuine article -
Has a sticker on it saying - 'Don't update software from other place, for it maybe damage the receiver. For new software, please go to ########### - At the back it has a 'V 2.0' sticker, together with S/N. Box came with Manuals, Cables, R232 Chip, NULL Modem cable, HDMI, HDD mounting Kit...
Seems an awful lot of stuff that would be very strange if packaged with a clone??
Genuine box's don't come with cables to recover it when you kill it as they will always support the latest images.
  • Like
Reactions: Ev0
Hi Guys,
Thanks
I am having the same problems. You have a VU+DUO CLONE, and there are necessary with IC update of your device to stay compatible with the newest firmware images
