Army_NexGenSmoke-FHD BH.: 3.0.8
Need more info
Do your box crash when starting Filebrowser
If possible post screenshot and if box crash post a crashlog
Its fixed and i will send an update to Ev0 and you can update the skin from the Addons later
I will give notice when update is avalible here at this thread :)
Thanks for the feedback its allways nice when bugs gets detected so we can fix them :)
Yes i know now installed the plugin to check my self.
I have also fixed it but i cant upload to the skin feed so waiting for @Ev0 to repack and upload the update :)
Problem was the button code.
Standard code is key_red for red button and so on but this author have use his own little twist ;) and named the button with only color. So in this case the code was red
and in second screen code change again now to buttonred ;)
So if it was not for the master @Matrix 10 and all his skin refs i got i would have been digging into the python code to find why the screens did not work.
But all in all its fixed and an update is on its way.
I will post here when update is avalible :)
Thank you,
I'm new to Enigma 2 so I tried various BH settings and skins to get my receiver in order so others can use it to watch TV.
I noticed that a lot of skins and various official addons are not compatible with each other.
I will try to bring those experiences to this forum.
Hallo Thomas
Can you upload a skin.xml file or part of the correct code until the official update disappears.
Greeting
Skin has been updated and can be upgraded from the Download manager where you installed the skin.
Whats in the update.
1 New encryption system added (verimatrix) into the Extra Infobar.
2 bug fix in common interface assignment screen for adding channels.
