Asking for help scanning with Ultimo
ruvain
Hello everybody
I hope somebody can help me as I can't find the solution for a trivial issue driving me crazy...
Before description my system's configuration is :
VU+ Ultimo with DVB-T/C tuner as tuner A and DVB-S2 tuner as tuner B
On the the roof 4 LNB's are attached to one fixed dish. each LNB have two RF cables going out of it towards the Diseqc. the LNB's are watching following satellite:
Hot bird 13.0 E , Amos 4W, Nilesat 7W and if I am not wrong the fourth LNB pointing to Badr satellite on 26W.
Now to the problem..... No matter which scan method I employ, no matter which satellite of the above mentioned I choose: Blind\Automatic or manual, or if I'd chosen any of the possible sats to be assigned to one of the: A/B/C/D ports on the Ultimo, it will always will treat it as 4W.
Meaning for instance scanning 13W regardless of assigned port one of (A to D), resulting scan will be the TV stain available on Amos 4W , and so with all otter sats.
Can anybody help please?
Thanks in advance!
ruvain
