Aspect ratio for mkv video
houbahop
Hi,
some mkv or mp4 videos have ratio different than 16/9 or 4/3 exemple 1920*808.
normally these videos are displayed on screen with black stripes at top and bottom.
But in blackhole, movies are streched and there are no stripes.
I tried to change display parameters : letter box,..., refresh frequency...,... with no result.
I specify that the problem is only with blackole image. (normal with openatv)
The display parameters are only for live TV; for file there should be a plugin, but I cannot check for it at the moment.
Hi,
Try Mediaplayer 2 for playing it and use the button (5) at your RCU to exchange between at the different modes video policy.
Download it from the addons feeds.
I don't know why I must use a player like Mediaplayer because internal player is able to read videos. The only problem is the ratio of some
So, try the other solution: there are two plugins; aspectratioswitch (if I remember well) and Letterbox. Trying them is for free... ;)
Hi Alexwilmac
I solved the problem :
I installed aspectratioswitch
I configured it in green panel :
set aspect ratio on setup : yes
startup aspect ratio Always 16:9
Then Restart Gui
I can uninstall aspectratioswitch. It continues to work !
Thank you for your help :)
I used only a long time ago but, if I remember well, there should be the chance of configuring its actions, for instance assigning them to coloured buttons or others. Try in the plugin's configuration.
