Audio delay duo2
birdman99
i am having serious issues with blackhole on my vu duo2 the last image I had was the latest and that was problematic . Then I installed 214 and now I'm having audio delay so when people are talking on TV it looks like an old Bruce lee movie.
I've tryed changing from Islas but no joy.
No problems with my Duo 2, have you tried changing the audio sound track, to see if the problem is still there?
Which channels are you experiencing this problem with?
Try backing up your channels, using dreamboxedit, then re-loadBlack Hole 2.14, but don't install any backup, if prompted, instead scan the satellite you're on and see if the audio problem is still there.
After 6 months, I hope you've got it sorted, if not try posting more information, regarding your satellite set up, and the channels you've tried.
I have this "problem", too. If I see TV via HDMI on my LG LCD unit and hear Audio of same channel via cinch output of my Duo2 with external amplifier (old analog Denon) and boxes, the TV comes 50 msec later. I think, this is happening because of digital signal processing in the TV (remember: SD and HD signal don't come at the same moment over satellit, too. The difference can be in the range of seconds!). I use the Audio Sync plugin to synchronize Audio and TV.
