Audio in Navi-X (temporary solution)
Shiro
BH-C
This is a temporary solution but is working at the present in my box.
1) install Navi-X
2) Map the mute button to ContextMenu as eplained here http://www.vuplus-community.net/board/threads/howto-context-menu-and-sumenu-in-xbmc.20591/
3) Launch Navi-X
4) Select the media you want to watch
5) Push mute button to access Submenu
6) Select Set Default Player
7) Select PAPlayer
8) CLOSE THE OPTION MENU
9) Select again Set Default Player
10) Select Auto Select
11) Close the menu
12 Run your file.
I have made this procedure for two times and now i have audio in Xavi-X
Let us now your experience.
Ev0
Admin
1) install Navi-X
3) Launch Navi-X
7) Select PAPlayer
11) Close the menu
12 Run your file.
Working perfectly :)
stainless
I replaced the file based on the link provided above and I can get sub-menu for Vu+ Duo2 and XBMC as well but the mute button is not working in Navi.
Any suggestions why?
antoine3_dupres
Even with all of this, the mediaplayer2 is started, but i do not get image. The dvdplayer of kodi gives image with no sound. I am on bh 3.0.2 with a vu duo 2
