audio level
thebigciro
Hello, i just installed open black hole but the audio level is very low. To hear properly i need to go up to 50 or 60 percent of audio level while usually i remain on the 20 percent with blackhole image. I remember that going in blackhole with the yellow button i could adjust the audio level. In open blackhole that is impossible. Is there an hidden menu, setting, plugin i missed somehow? Please help as i don't hear almost anything.
When you flash a new image, the audio level is by default 50%, so on your RCU, increase the level audio volume to the amount you need.
I change my 50% default by using web control on VU+ Web Control, this will turn the volume up on the VU
You only need web control ( openwebif ), to increase the volume of your STB, if you can´t do it with your RCU. ( Examples: RCU setted up to control the volume of your TV Set, Rcu malfunction ).
