Audio problem with some HD channels in DVB-C
gravatasufoca
We have some problem with the audio on some channels in DVB-C here in Brazil
Some HD services has no audio.
I am sending a sample for you to try fix it.
>>Get sample here<<
https://dl.dropboxusercontent.com/u/12772101/20160406%201606%20-%20SBT%20HD%20-%20Bom%20Dia%20%26%20Cia.ts
>>Get sample here<<
Ask your provider, for this issue!
Same issue here, different image here --> http://www.vuplus-community.net/board/threads/audio-problem-with-some-hd-channels-in-dvb-c.28210/
Other distro the audio is OK.
OpenAtv, OpenPli, OpenVix, OpenDroid, in all those the audio is working. Maybe is not a provider issue.
So I think is a problem with BH, the audio only doesnt work on BH and OpenBH.
Thats why I send the TS file.
But thanks.
But thanks.
Sorry, but OpenBH ... is OE-A based and fully compatible with OpenATV plugins.
More: Open BlackHole 01 ... is fully compatible with OpenPli, because is OE-OpenPli based.
You must check your settings ... We can't investigate your issue, why?
  • You are talking about an encrypted channel.
  • Geographic location ( we are in Europe ), you ara in Brazil or South America.
One more time, according our board rules ... it´s not allowed the discussion ... about any kind of illegal stuff ... emulators or not!
You don´t need too, spamm your issue, i.e., open the same thread with same dought.
nungaia
Two threads in two different images. Do They share the same issues? If so, ok, my mistake.
I think the audio problem is not about a plugin compatibility, is a driver issue.
The channel I sent the TS file was not encrypted when I recorded.
You were clear now, You cant investigate MY issue. Thanks.
