Auto channel audio selection?
bevste
Is there a plugin available to do this? Most enigma 2 boxes have this in the menu including Black Pole but not available on Black Hole images and this is my preferred image! I know you can go through all the channels and change them manually but if the box crashes then normally they revert to the original settings and its annoying and time consuming to change them again. Yes i know i could back up my settings and reinstall if there is a problem but it would be so much easier if it was available in the menu!
The feature you want is part of Pli images and it's avaiable on all images based on Pli code like BlackPole (and others too).
BH images are based on Official SDK provided by Vu+ company.
I appreciate the explanation but i prefer the stability of the black hole image! I had just hoped that some coder had perhaps created a plugin to do the same job! :thanks:
