AUTO language selection not working H=BH 2.01V
thameur101
AFTER setting the default language to english and select italian and spain chanel the default language playing is contry provider i select audio and switch maualy to english :sad:
AFTER setting the default language to english and select italian and spain chanel the default language playing is contry provider you must read first with audio button you will found audio undetermined so you need to set this as language in you auto language then you can have original audio for that provider :thanks:
The problem is into the SAT TS stream because the language is not declared (Undetermined). Auto Language function works properly when the language is declared into TS stream (I've tested some Swiss channels and works properly).
So would it be possible to add "Undetermined" to the list of languages to auto-select?
I've not tested on this image yet but using a different image, auto language didn't like different spellings - eg Englisch instead of English used by German channels.
auto languages in version 2.0.1 has "Undetermined" and you can select it ...
you can order audio languages , for example :
1- English
2- Deutch (German)
3- Undetermind
4- Arabic !
Excuse me for bad English !
