Auto search problem
yashar1357
Hi,
I am facing with a problem on auto search. When I start, it doesn't ask for which satellite and automatically starts with Hotbird although I am on another one. Any suggestion ?
Vu Duo, 110 Dish with Jack, positioned manually.
Thanks
Check your tuner configurations to where U identified LNB1 & satellite name!
and it would be nice to choose which SAT , Auto search can start with,,,but as far as I know it is not possible!
Thanx a911
I have tuned 4 satellite as bellow:
Turksat LNB 1 position 1
hotbird LNB 1 position 2
Astra 19.2 LNB 1 position 3
Eutelsat w3 LNB 1 position 4
is this correct or LNB should be change for each sat.?
Thanx a911
Yes, LNB#... should be changed for each sat!
I did it . still doesn't work. but finally found the way.
1- Go to manual scan.
2- Set scan type to single satellite.
3- select your desired sat.
4- start.
4- start.
It will work....however its not only the LNB# U have to change,,,!
later on , will post some tuner config settings,,,as an example for you to follow!
RgdZ
a911
4- start.
As promised 2U yashar , here a few exampale for 4 LNB,,,,the same could be made for more LNB's
Look @ the settings and adopt yours to that,,,,keeping in mind that may be a few changes have to be made and configured by U,,,,its always Fun and Easy w/BH!
RgdZ
a911
Thanx a911
Really advanced setting .works fine. would you pls. give an info. about priority option and its application?
kind rgds
Thanx a911
kind rgds
Do not know:grin:!.....I guess it points to which SAT # ,will start first @ Auto Search!
Just keep it @Auto....;)!
