Auto shutdown in openbh (put on standby)
javierc
Hello, how can I configure openbh to auto-shutdown (put the deco on standby after a few hours of inactivity) as it was done in Black Hole?
Regards
Regards
I found how to solve it was easy:
Menu - timers - Power Timer list
Select Power timer list and press the green button to add and select:
- timer type - auto standby
- night delay - the time you want it to wait from the last time you pressed a button on the remote until it goes into standby
- repeat type - repeated
The options may differ because I have translated them from another language, but in your deco they will appear similarly.
