Request Automatic load/select subtitles!
snowboard
Is there any way or pluggin that can automatic select the srt subtitles without need of press the txt button and ok?
There are no one intetested on that ???????????????????
Black Pole image has indeed the ability to choose subtitles automatic aswell as the srt subtitles for media files and in combination with the enhanced movie center plugin you also have the subtitles for dvd`s automatic shown.
Furthermore you also can adjust the size and position of the subs.
Thanks of your answers.
I think pli does that too, but i'm using vti that of all the images that i've tested, seems to bee the best and more stable!
I've not tested yet the blackpole... that seems to be excelent if it does what you are saying!...
... but... is that exclusive from blackpole? is it possible to copy that to mine? Is that a plugin? How can i do it?
No, but BlackPole is based on OpenPli so also has this great feature onboard, settings are in the menu.
There is no plugin available who can do this and no you can`t just put it in vti.
