Automatic Scanning on BH 3.0.5
Contact99
I would like to get a simple answer to these three questions as someone must know this.
I have a Ultimo 4k using BH 3.0.5 and I have manually added ALL my transponder for years even on my Duo2 and now for the first time I have used Automatic Scan.
See for years I always Scanned Manual scanning and only for FTA ONLY and I noticed now when I scan AUTO it scans Encrypted channels too as I dont have a Option where to Scan FTA ONLY.
Now that ok as I can generate a Favorite for each Satellite and put the FTA in my favorites also I have noticed that the Ultimo 4k Hops to 17 Satellite C and Ku Band on my system which takes 1.1/2 hours to do.
Now for the three question I would like to be answered
1/ Does the Ultimo 4k box only scan what in my own XML files in the box and in my DVB EDIT or does it scan other frequencies that I don't know about being in Auto (I know it has no blind function).
2/ When you do a Auto scan can you do a Single satellite not all of them
3/ I have notice that when Im on a Satellite that I want to Auto scan when I start the scan it start on another Satellite and in any order. If there a reason why it does this As it might scan "A" Satellite and the next one to scam is 80 degrees away and when its finishes it come back to the Satellite NEXT to the one It scanned before. Yes it goes back and forward from my motorized Dish to Fixed C and ku Band dishes, Its all over the Place.
You would think it would have a process to start from Say as an example start from Asiasat 5 at 100.0 5 Deg and go from there to Asiasat 7 at 105.5 deg E and goes to next satellite next to it as at the moment its everywhere.
What do you think? is there a setting in the box that I have missed or can it be fix this or is it like this.
Hope someone can answer this for me and others that still read these forums for some info.
Thanks all
